Wiireless Keypad Entry with Safewatch Pro 2000 (SA20-ADT, SA5882-2H)
Old 06-18-11, 09:05 PM
B
Wiireless Keypad Entry with Safewatch Pro 2000 (SA20-ADT, SA5882-2H)?
Hi,
What keypad(s) can I use with my Safewatch Pro 2000 (SA20-ADT, SA5882-2H) base unit to add a wireless keypad. Do I need to change any boards?
Thanks!
Old 06-19-11, 10:59 AM
B
I also need a wireless smoke detector.
Old 06-20-11, 09:29 AM
Received 92 Votes on 85 Posts
What you have is a modified Vista 20se.
In order to make changes to zones, you need a 2-line alpha keypad (6139 or 6160 or equivalent). Some of the wireless keypad models require the bi-directional module (5800TM), but the more basic ones don't.
Whether you need to change your wireless receiver, depends on _which_ wireless keypad you are trying to use.
Old 06-22-11, 11:13 PM
B
I do need a wireless entry keypad because running more wires is a big job. Looks like I will need to find a keypad that does not require bi-directional RF.
If you know of any let me know. I also need a fire alarm (wireless again).
thanks!
Old 06-23-11, 03:22 AM
Go to the source and read the specs:
Wireless Products
Old 01-28-12, 02:16 AM
B
Would it be possible to replace an existing old keypad with a 6160RF keypad, and use it's built in 5800TM module with another wireless house entry such as a 5828 keypad? The idea here is the 5828 would communicate with 6160RF to the main controller.
It is difficult to figure out which units to use since the manual are terse, and do not give much explanation.
Old 01-28-12, 02:56 AM
Yes, that combination will work just fine.
