Protection one monitor 100 check problem
Old 10-28-11, 08:56 AM
I have a protection one k3743 M6829 monitor that keeps flashing 100 check. I dropped Protection one but still use it unmonitored. Can anyone tell why it flashes 100 check and how to clear it? Any help will be appreciated.
Old 10-28-11, 11:34 AM
Received 32 Votes on 31 Posts
Those part numbers are for the plastic shell on the keypad. The actual system model number is on the diagram inside the door of the metal box with the motherboard and battery.
In any case you probably have a modified Vista 20p. Check 100 means that either communication with the wireless zone expander is faulty, or you have such an expander with no devices enrolled.
Protection one doesn't make hardware. They pay companies like Honeywell to put the P1 logo on the equipment, often with minor software modifications.
Old 10-28-11, 02:08 PM
kcxj's Avatar
Protection One has used the 6150RFPL2 for many years. The earlier models utilized a tamper switch on the keypad, which can fail or need to be adjusted. Sometimes you can apply a piece of card board or tape to help hold the tamper swith down inside the keypad. You will need to enter your code + OFF, twice to clear.
Old 09-25-12, 09:45 AM
Ademco Vista - 20p no contact with wirless divices
My keypad keeps telling me to check zones 10,11,12,13 & 18 these are all wireless. It seems the system has lost communications with all wirless devices. Can someone provide and help? Thanks
Old 09-25-12, 07:36 PM
kcxj's Avatar
If all zones are in check, then the reciever is probally bad. You will need to replace the keypad with a 6150RF or turn off the reciever in the keypad and add a 5881 receiver.
