How to disable the telephone line alarm on the DSC PC2550 alarm system♥
Old 11-19-11, 07:11 AM
Hi all,
I recently moved into a new house which has a DSC PC2550. The system works fine but the yellow trouble LED indicates that the telephone line is at fault, which is correct since my system is not connected to the telephone line, which is my preference.
Is there any way to program or configure the DSC 2550 to disregard that non-existant telephone line and therefore extinghuish that particular fault signal.
Thanks for your help
Old 11-19-11, 08:22 AM
Received 38 Votes on 37 Posts
First, you are going to need a manual:
dsc pc2550 installation manual - Google Search
You will find an installer manual in the first 5 search results.
Since this system is new to you, if the default installer code (located in the manual) doesn't allow you into programming, about all you can do is a hardware default and reset everything from scratch.
The actual sections you need to alter is programming location 15 (turn ON option 1) and programming location 16 (turn ON option 7).
Read through the manual (yes it will be a slog) and we can help you with the parts you don't follow.
Old 11-19-11, 11:33 AM
Wow that was quick,
It worked and everything is fine. Thanks for your most valuable advice.
Old 11-04-12, 03:01 PM
I have the same issue. The trouble light is lit. Would you be so kind and simplyfy your solution. I have downloaded the manuel. But not quite sure how to solve the problem.
Respectfully
Old 11-05-12, 03:43 AM
*8 [installer code]
15
press 1 and the zone 1 LED will turn on
press #
16
press 7 and the zone 7 LED will turn on
press # until you exit programming.
