Concord Low CPU Batt
Old 11-21-11, 07:41 PM
K
Exclamation Concord Low CPU Batt
I have a fairly new Concord alarm system--we moved into our newly constructed home June 2010. We had a tornado go through our subdivision a few days ago and of course we lost power. When power was restored 12 hours later, the Touchpad periodically shows "Low CPU Batt." I figured that it would just need time to recharge the battery (they recharge, right??). But it gives me this warning by sending out 4 or 5 beeps at exactly 3:46 AM. Yes AM.
Funny thing is, sometimes it says system is ok...Tonight it said system ok, but I ran the sensor test and the touchpad immediately displayed the 'Low CPU Batt' again. 15 min later, it says "System ok." Any ideas? Do I need a new battery or is there maybe a bad wire somewhere?
Any suggestions would be greatly appreciated!!
Old 11-22-11, 04:47 AM
Received 101 Votes on 93 Posts
These batteries often don't recover from a deep depletion like you had. Replace the battery, if it hasn't recharged by now, it's not going to.
Old 11-22-11, 05:58 AM
K
Wink
Thanks for your help! Do I need to turn off AC power before changing the battery? What is exact process for changing battery (remove red before black, etc)? I appreciate it!
Old 11-22-11, 10:43 AM
It's 12V. Unplug the connectors and plug them onto the new battery; no need to power down.
For various technical reasons, it's better to disconnect the negative first and reconnect it last, but at these current levels, it honestly doesn't matter.
It may take up to a day for the system to run the battery test again, and clear the trouble.
Old 11-22-11, 03:23 PM
G
Do a sensor test after you replace the battery....it'll check the battery voltage and clear the low batt
Old 11-22-11, 06:56 PM
K
Thank you guys! I replaced the battery as so far all looks good!
Old 03-07-12, 08:11 PM
N
Battery Location
I took the cover and checked the back panel but I don't even see where the battery is located or any parts that are removable. I didn't install it so not too familiar with the product. Any help would be appreciated.
Thanks
Old 03-08-12, 04:29 AM
It's not behind the keypad, it's in the metal box with the motherboard typically located in places like the master bedroom closet, or a utility room.
Old 03-08-12, 05:41 AM
N
Thank you. I got it figured out now. It's all coming together!
