Ademco Vista 20p help with function keys
Old 12-08-11, 11:22 AM
A
I programmed the function keys on my system with A being Armed Away and B being Armed Stay. The other two are not used. If I arm the system using the function keys I cannot disarm it with my code. I obviously did something wrong. The only way to disarm it is to remove power from the panel. Once I do that I can arm it and disarm it using my code but if I use the function keys again I am not able to disarm. Any ideas on what I screwed up?
Thanks in advance.
Old 12-08-11, 11:58 AM
Received 89 Votes on 83 Posts
I'll bet you are trying to disarm with the _installer_ code instead of the Master code. The installer code will _only_ disarm the system if the installer code was used to arm it.
