How to set Panic button FA1600
Old 01-25-12, 06:46 PM
7
My wife has decided that she needs a quick panic button for the alarm. I thought I set it with *22 and then hitting 100 to set the first button series of *1 for the panic button sequence and not enabling the next two button series but it is not arming. What am I missing?
Old 01-26-12, 03:32 AM
Received 241 Votes on 220 Posts
For what it's worth, a FA1600 is a Vista 100.
The default zone type setting for zone 995 (* + 1) is 00 (disabled). You have to assign it a panic zone type.
The only panic key combo that has a default zone type is [* + #] (zone type 06)
Old 01-31-12, 05:31 PM
7
Thanks for the reply. It has been so long since I set the system up I've got to review zone types. I may be back to ask more questions.
Old 01-31-12, 07:33 PM
7
I cannot believe I've forgotten everything I learned on setting this up. I have a siren that goes off when triggered. How do I trigger the * +1 to make the siren go on for the panic? I've enabled 995 but do not remember how to set the zone. I started hitting #93 and could not remember what any of the language meant and continued to hit 0 till I finally got out. I may have even disable something for all I know.
Old 02-26-12, 04:26 PM
7
Ok, been reading the books again and thought I had it figured out. Went 999 for zone for the * = # buttons to make the alarm go off. Not going off when hit. Tried 07 and 09 for zone type, partition 1, report code 07, bell 1, hardwire 01? I'm going off of memory but this did not work.
Can you walk me through were I went wrong?
Old 02-26-12, 05:24 PM
This is enough of a PITA that they actually have a separate document on the Honeywell site to explain the darned thing.
"Vista 100
Procedures for Enabling Keypad Panics
1. Enter the [Installer code] + 8 + 0 + 0 + 0, screen displays
“PROGRAM MODE * FILL # VIEW-00”
2. Press *22, screen displays “KEYPAD PANIC ENABLES”
ENTER 1+1+1
3. Press *85, screen displays “KEYPAD PANIC AND DURESS
REP” Enter 1+1+1+1
4. Press * or # 93
5. Screen displays, “ZONE PROG?”
6. Press “1” for yes
7. Screen displays “PROGRAM TOOL” enter “0” for no.
8. Screen displays “ENTER ZN NO.” enter 995 (1 + *) then “ * ” to proceed.
9. A summary of that zone’s programming will be displayed, Review as needed then press “ * ” to proceed.
9a. ZT = Zone Type
P = Partition #
RC = Report Code
B = Bell/relay select
INL = -----------
10. Screen displays, “ZONE RESPONSE” enter the selected 2 digit
zone response type then press “ * ” to proceed.
10a. 00 = Unused Zone
01 = Entry/Exit #1, Burglary
02 = Entry/Exit #2, Burglary
03 = Perimeter, Burglary
04 = Interior Follower,
Burglary
05 = Trouble Day/Alarm Night
06 = 24-Hr. Silent Alarm
07 = 24 Hr. Audible Alarm
08 = 24 Hr. Auxillary Alarm
09 = Fire Without Verification
10 = Interior Delay, Burglary
16 = Fire With Verification
17 = Fire Waterflow
18 = Fire Supervisory
19 = 24-Hour Trouble
20 = Arm Stay ⊥
21 = Arm Stay ⊥
22 = Disarm ⊥
23 = No Alarm Response(e.g., Relay activation)
10b. ⊥ These are special zones used with 5800 Series Wireless Pushbutton Units that will cause the system to arm in the Stay or Away mode, or to Disarm, depending on the selection made
11. For “REPORT CODE” Enter the report code. The report code consists of 2 hexadecimal digits, each in turn consisting of 2 numerical digits. Press “ * ” to proceed. For example, for a report code of 3C, enter 03 for 3 and 12 for C. Possible entries are:
11a. 00 = 0 04 = 4 08 = 8 12 = C
01 = 1 05 = 5 09 = 9 13 = D
02 = 2 06 = 6 10 = A 14 = E
03 = 3 07 = 7 11 = B 15 = F
12. For “BELL/RLY SEL” enter the number corresponding to the combination of bells and/or relay you wish to activate when zone goes into alarm. Press * to proceed
12a. 0 = None 1 4 = Aux. Relay
1 = Bell 5 = Bell 1 and Aux. Relay
2 = Bell 2 6 = Bell 2 and Aux. Relay
3 = Bells 1 and 2 7 = Bells 1 and 2 and Aux. Relay
13. Screen will show summary of that zone’s programming, Review as needed then press “ * ” to proceed.
13a. ZT = Zone Type
P = Partition #
RC = Report Code
INL = -------
14. At “ENTER ZN NO.” enter 996 (3 + #) or 999 ( * + #) then refer to steps 10 thru 13. If no other programming is desired press 000
+ “ * ” to exit zone programming.
15. Screen displays “QUIT MENU MODE’” enter 1 to exit.
16. Screen displays,“PROGRAM MODE * FILL # VIEW –00” enter
*99 to exit program mode."
Old 02-26-12, 05:36 PM
7
Wow. Way more to it than what the manual was showing. Thanks.
Old 02-26-12, 06:57 PM
Oddly enough, for the Vista 100/FA1600 being the largest and most complicated of their systems; the manuals are the worst written of the lot...
