Adding a zone to my Ademco SE-10 Vista with a 6128 (numeric) keypad
Old 01-29-12, 05:37 PM
Well, here goes... I would like to add a new hardwired zone to my current system. Since I have 1 h/w zone already (01) this would be numbered 02. Here is the sequence of keystrokes entered and the results I got.
xxxx 8 0 (installer code
*56 (programming mode
1* (confirm yes
[At this point my screen showed a 20... so I think things went astray]
02* (zone 02
* (accept summary
01 ** (zone type 01, use default )
11* (default report
* (input device type - should default to HW so no entry required for serial number and loop number)
* (confirmation option
* (summary display
0* (no alpha descriptors
00 (quit)
Needless to say, it didnt work so I powered off and got the system back to ready mode at least
Thanks
Paul
Old 01-30-12, 06:09 PM
To program zone 2 as delay press (IC)(80). The display should read 20. Press (*)(56)(*). The display should read 01 for zone 1. Press (02)(*)(*) then (01). This will make zone 2 a delay zone. Then keep pressing (*) a few times until the display reads 03 for zone 3. Press (00)(*) to exit the zone menu then (*)(99) to exit programming. In the future you should get a 6160 keypad. It will make programming much easier.
Old 01-31-12, 04:04 AM
I bought a used 6139 alpha keypad... When I get it, I will do the programming. THANKS
