DSC Power832 Security System Help
Old 02-28-12, 10:45 AM
F
I have a DSC Power832 PC 5015 v2.2 Security System with Memory and Fire lights that will not clear. The ready light is on and no alarms sound but can't clear these two lights. Any suggestions?
Old 02-28-12, 10:57 AM
Received 241 Votes on 220 Posts
The memory light will clear the next time it's armed/disarmed. *72 normally resets fire devices. (per the user manual: DSC - User Manuals)
Old 02-28-12, 11:05 AM
F
No luck with the resetting fire devices with *72.
Old 02-28-12, 01:34 PM
Do you actually have smoke detectors or heats (wired or wireless) on this system?
It's hard to advise you without knowing what you actually have attached to the system.
Old 02-28-12, 03:46 PM
F
Yes, we have smokes wired in.
Old 02-28-12, 06:32 PM
Do any of the smokes have the red LED locked on?
If not, simply try powering down the system (AC power and battery) and re-starting (no you will not lose any programming, just reset the clock).
Old 02-29-12, 01:25 PM
F
Thanks for the advice I powered down the system both AC and Battery. It cleared the Memory and Fire lights but now my Zone 7 light (for Panic buttons) will not clear and the ready light is now not on. I put fresh batteries in the Panic Buttons and tested the system which sounded the alarm. I then cleared the siren but the Zone 7 light is still on.
Old 02-29-12, 01:29 PM
Did you press # to exit current alarm display mode?
Old 02-29-12, 01:57 PM
F
Yes I did press the # afterword.
Old 02-29-12, 02:08 PM
F
Ran the test again and cleared it. Now I have the Memoryand Ready lights are the only ones on. I can't figure this system out for the life of me and the user manual is just this side of useless.
Old 02-29-12, 02:25 PM
F
Read more: http://www.doityourself.com/forum/el...#ixzz1noQkCmWo
Old 02-29-12, 03:07 PM
DSC manuals are notoriously terse. The information is there, but often, critical info is one sentence buried in a block of text.
The installer manual _must_ be used with the programming worksheets. Either is meaningless without the other to reference.
You have to pretty much scan through the whole thing, cover to cover (repeatedly).
Arm the system, then immediately disarm and the memory light will go away.
Old 03-01-12, 04:35 AM
F
A million thank you's I'm back in business! I truly appreciate all your troubleshooting
