Alarm keeps sounding
Old 03-15-12, 10:35 AM
P
We installed our Nutech by Nutone alarm system in 1987 when we built our home. Occasionally when the alarm begins to sound for no reason, it has been the smoke alarm which needs to be replaced. The alarm did begin to sound, and we replaced the smoke alarm, however, it is still continuing to sound. Any idea as to what might be causing it this time?
Thanks.
Old 03-15-12, 08:40 PM
T
Doesn't your keypad/system tell you information about the alarm?
If you are not arming the system then it is probably the smoke since it's 24/7.
Are you sure that it is an alarm and not a trouble?
Old 03-15-12, 09:23 PM
P
We lost the stupid book. How did we do that?
Previously, replacing the smoke alarm solved the problem. But, not this time. When we replace the smoke alarm the indicater lights on the smoke alarm don't change. Are they suppose to? We're not certain that the pad is showing the same thing as it did last time we had the problem. It's been a year. It's always about a year between incidents.
