GE model 60-746-01
Old 03-26-12, 09:18 PM
B
GE model 60-746-01
Hello all, I was hoping someone could help. I moved into a house that has a GE 60-746-01, I tihnk it is one of the concord model from what I see online. I would like to be able to use it without a monitoring company but have to codes whatsoever.
From searches on this and other forums I have found numerous codes. Using 8+2580+3 I can access a sensor test, using 8+2580+2 I can access a phone test but can do nothing else!
Is there anyway I could just reset the could to use the system?
Thanks
Old 03-27-12, 03:23 AM
Received 241 Votes on 220 Posts
That's the keypad part number. For the system model number look at the diagram that's normally inside the metal enclosure with the system motherboard and battery.
Old 03-27-12, 08:21 AM
G
"2580" is either the master code or the installer (or dealer) code. Try 8+2580+00...do you see SYSTEM PROGRAMMING?
Old 03-27-12, 04:48 PM
B
To answer both questions-system has 2 numbers listed, 60-806 and 69-806-95r. When I try the 00 or any other code other than sensor test3 or phone test 2 it just beeps twice and goes back to main screen
Old 03-27-12, 06:47 PM
G
00 isn't part of the code, it's a command....Sounds like you have the master code. Try 9+2580...does that get you to TIME AND DATE?
Old 03-28-12, 06:38 PM
B
My apologies. No commands work other than +2 or+3. 9+2580 only gets me 2beeps and. Retweurn to main screen.
Old 03-29-12, 10:42 AM
G
bad news...looks like you have neither the Master of Installer Codes..not much you can do here
Last chance check, does 9+4321 get you to TIME AND DATE?
