Security Manager 2000 not seeing Ademco 5816 wireless sensor
Old 07-25-12, 12:18 PM
Like a dummy I knocked the door sensor, breaking the little plastic posts on the door frame mount which fit into the keyhole slots in the sensor. Luckily (or so I thought) the actual screws holding on the wall plate fit the keyhole slots.
But now the sensor isn't working. I opened it up and the tamper switch works and gives a fault, so the receiver sees the switch, but no chime and no ready light unless I bypass the zone.
The system is not monitored, to I'm hoping to resolve this myself.
Thanks for your help!
Old 07-25-12, 06:39 PM
Received 31 Votes on 30 Posts
When you take the cover off of an Ademco style contact, the tamper switch doesn't reset until you enter your user code +1 (off) to clear the tamper.
Also, double check how you mounted the contact. Did you align the little raised mark on the side of the transmitter with the magnet?
Old 07-25-12, 07:23 PM
Resolved!
Wow, I am truly dense....I ASSumed that the keyhole slots would face down, so I was mounting the sensor with the raised marks facing away from the magnet.
What a relief,
Thanks!!
