Honeywell Galaxy Dimension Wiring with artech DD497AM detector?
Old 08-20-12, 04:39 PM
Hello All,
can someone tell me how to connect them please ?
1 -0V
2 +12
3 Alarme
4 Alarme
5 Spare
6 Tamper
7 Tamper
8 NC ETO
9 C ETO
10 Day/Night
11 Walk Test
Galaxy Dimension
Z1, 0V, Z2, +12V
Thank you very much in advance for your help.
Old 08-20-12, 05:19 PM
Received 38 Votes on 37 Posts
0V to 0V
+12V to +12
The two alarm connections go to a zone input and it's common, with the zone resistor in series with either leg. All the other terminals are for optional functions, most of which are rarely used in residential installs.
Old 08-20-12, 07:43 PM
Thank you for the quick reply , very helpful .
this is for one Detector on one zone , what if i would like to connect many detectors on the same zone .
Old 08-21-12, 04:45 AM
It's generally recommended not to put multiple motion detectors on the same zone input, but if you want to, you would just be connecting the alarm inputs in series (not parallel).
At the alarm control end, you take the pair of wires connected to the alarm output, and connect one of the pair to one of the pair from the next device's alarm output. The two free ends left go to the zone input and common.
The power always connects to the same power terminals.
Old 08-21-12, 12:55 PM
The Galaxy Dimension is double balanced. 1k closed and 2k open, so you need 2x 1k resistors. You wire the zone to one tamper connection on the sensor, then the other tamper connection on the sensor to a 1k resistor. The other leg of the resistor then goes into the contact switch on the sensor. The second 1k resistor goes across the sensor switch, with the other zone on the other side of the switch. It's in the manual
Old 08-21-12, 06:18 PM
ok thank you very much , i will put only one motion detector on one zone .
I managed to test two and it s working perfectly now with resistor Option 9 (1K 2k).
Next step i will have to connect an door opening detector (BECUWE IM1640PAG) and one outdoor Siren (HPA702LG ELKRON) will have to test the wiring too .
I am testing it in a small space before putting it in it real place .
Old 08-21-12, 06:23 PM
galaxy , it s true that it s in the manual , but i wanted to have some expert suggestion , now my setting up is picking because of your help , not the manual . Thank you again
