L5100 Program menu
Old 09-20-12, 12:38 PM
L5100 Program menu
Last week i installed a new contact device, when a exited the program menu, i made a error i accidently selected to lock the program menu..... How to unlock???
Old 09-20-12, 01:23 PM
Received 32 Votes on 31 Posts
Look around page 22 or so of your installer manual:
"If you do not have access to the current installer code of your LYNX Touch, power the system down. Upon initial power up, while “SYSTEM STANDBY!” is displayed, press and hold the OFF key until the L5000 or L5100 stops the system initialization. Press the OFF key a second time and the system will display the keypad. Press the “Clear" key and you will see a blue vertical bar underneath the “Enter Code.” Enter 00 on the touchscreen and the system will move to the Installer Tools Menu. You can now follow the steps above to set a new installer code on your LYNX Touch."
Old 09-20-12, 02:11 PM
So the reason i had so much trouble is that i didn't had a OFF button......
OFF button on the L5100 is the UNLOCK button !
Thanks for the help MrRonFL
