Vista 20P + 4204 Relay + GRI Pool Alarm
Old 10-05-12, 06:46 PM
I have an existing alarm panel GE NX6 with a GRI Pool Alarm. The pool Alarm is tied into the GE NX6 through a built in panel relay.
Everything is working and Chiming correctly.
All the Sliding Doors that go to the Pool Area have 1 set of contacts on them so the Pool Alarm and the Alarm are using the same contacts.
I am trying to get the Alarm monitored but we are locked out of programming.
Because we are locked out of programming I am replacing the GE NX6 with a Honeywell Vista 20p and was told that I needed to get a 4204 relay. I now have the New Panel and Relay but am looking for help on getting the Pool Alarm tied in so I don't have to add sensors to the system.
Old 10-05-12, 10:30 PM
Received 38 Votes on 37 Posts
Have you tried using the DL900 software and a direct connect module (NX-586/588)? That will bypass the installer code and allow you to view/change it unless the original install did something unusual.
That said, which model of GRI alarm do you have? There are several, and they don't all wire the same.
Old 10-06-12, 07:58 AM
the nx6 is gone, vista is in now. the gri is a 289
Old 10-06-12, 09:55 PM
Were I to guess, your previous setup was using the alarm control output to trip the input points on the pool alarm when a specific type of zone was tripped.
For the Vista panel, you will do something similar, only you will need to program a relay on the 4204 to change states when the zone(s) in your pool perimeter are tripped.
