Dsc pc1550
Old 11-02-12, 03:21 PM
Dsc pc1550
I am getting the "failure to communicate fault" every month since I stopped my monitoring. I am know using VOIP for my phone. How can I disable this so it doesn't beep every month. I called the old security monitors and they said they are not doing any tests with my system since I have cancelled.
Thanks
Old 11-02-12, 04:02 PM
If memory serves, that error is generated when the system tries to do a call to the monitoring company to verify itself or if an alarm has gone off and it couldn't dial.
Should be able to verify it with:
TROUBLE Light on, press * 2 and zone light will turn on
Zone Light 4 = Failure to Communicate
Anyway, assuming you don't want it to call out at all:
*8 [installer code]
(red armed light will come on) Then
press 0157#
press 3801###
That should be it.
Old 11-02-12, 06:48 PM
Thanks Shane I will try this tomorrow and keep you posted.
Old 11-02-12, 08:40 PM
Received 35 Votes on 34 Posts
Right idea, but you are getting the instructions for a PC 1550 and a PC1555 (a very different beast...) mixed up.
http://www.myalarm.com/manuals_prog/pc1550p.pdf
For a PC 1550 to disable the dialer:
*8 [installer code]
12 1 (turn ON option 1 in programming location 12)
# until you exit programming.
Old 11-03-12, 07:39 AM
Whooops! Glad you caught that!
Old 11-04-12, 08:33 AM
Thanks Ron. I tried it but I don't think I have the installers code. I have the other code but the not the installer code. i tried *8 then 1500 but didn't work. any suggestions
Old 11-04-12, 10:02 AM
If you don't know the installer code, and the installer lockout hasn't been set, then all you can do is default and reprogram everything.
First, determine if your system is locked out. Power down. When you restore power, listen to the motherboard. If you hear about 10 clicks from the relay above the telco connections, then it's locked out, and short of the lockout bypass posted in the Alarm Forum FAQ sticky, there's nothing to do but start over with a new system.
If it's not locked out, then you just need to make a list of your zones, so that you can reset the zone configuration after the default.
See page 13 of the installer manual.
