How do I program ademco alarm to call my cell
Old 01-16-13, 08:29 PM
B
Do i use the key pad to do this please help
Old 01-17-13, 02:32 AM
Received 44 Votes on 43 Posts
Need the system model number to give you any clues.
Old 01-18-13, 06:38 PM
B
Ademco 15 or. 15cn. I hope you can help me with this!
Old 01-19-13, 06:34 AM
Does this look like a match for your system?
http://www.systecalarm.com.br/manuais/novo/Vista15.pdf
If so, the best you can do is have it call your phone as if it were a "pager"
[installer code] + 8 + 00
*41* (only if you are deleting the central station monitoring connection or not using it at all)
*42 [phone number]*
*43 [any 4 digit number] (it needs an "account number" in this location)
*47 7
*99
If your system has previously been reporting to a central station, that should be all you need to do.
Old 01-19-13, 01:27 PM
B
I do not have the installer code also do I use the key pad to put this info in? You also mentioned +8+00 do you mean to put 8 00 in after installers code?
Old 01-19-13, 01:38 PM
B
The manual says I can put in *40* does that get rid of installer code and do I have to put in a installer code or can I leave it out after I delete code?
Old 01-19-13, 06:59 PM
Retrieving Installer code
Nearly all Ademco family (this includes First Alert, Security Link, and several ADT models) panels can retrieve the Installer code by disconnecting the battery, then the AC power. Wait a minute, then reconnect power in the opposite order. Within 50 seconds, on any keypad press * + # at the same time. Unless the system has had an installer lockout feature activated, the panel should go into program mode. The details by system will vary, but the programming section number that shows on the display will be the location for the installer code (on _most_ panels this will be 20). Key in # and the location number, and the panel will read back the installer code one digit at a time (ignore leading zeros). Exit program mode using *99.
Read more: http://www.doityourself.com/forum/el...#ixzz2ITsGl5y8
Old 01-20-13, 02:26 PM
B
Thanks it took me a little time but I did get it. Now I will have to do my daughters house. Not sure yet what alarm she has but I will repost if it is different. Hopefully you will be able to help me. Thanks again
Old 04-15-13, 10:37 AM
B
Can't get this to work
I have, probably, an Ademco 20p. I have the installation and programming manuals. I have entered my cell phone number in both the pager field *160 and the secondary phone# field *42. I cleared the primary phone# field. I put an account number, 0 0 0 1, in fields *44 and *46. I set report format *48 to Ademco ContactID 4 digit (7).
Any further thoughts?
Old 04-15-13, 04:37 PM
First, you need to verify your system model. A Vista 20se and a Vista 20p look very similar, but program completely differently.
Old 04-15-13, 05:05 PM
B
It's a 20p. The prompts (field names) are as expected in programming mode.
Old 04-16-13, 01:46 AM
Do you have report codes programmed for each zone, etc. that are supposed to trigger the dialer?
Has this unit communicated with a central station in the past?
Have you verified dial tone at the Telco connections for the panel?
Old 04-16-13, 07:58 AM
B
Thanks!
Have not assigned report codes, but expected that alarms, in/out would trigger call regardless. I will consult manual and assign codes.
Yes to having been monitored centrally (previous homeowner).
Yes to dial tone.
Do you have an opinion as to whether using phone field or pager field is preferred option?
Thanks!
Old 04-16-13, 02:12 PM
Use the pager field. The phone field is only for connecting with a central station receiver.
