dsc PC1555 control panel with PK5508 keypad problems
Old 02-08-13, 03:44 PM
G
Hi. I need some help.
I hard wired four zones to the panel, the zone 1 being a motion control. The others (doors) are all NC. I did not use any resistors, not even in the two remaining un-used zones as I assumed they could be programmed as null.
When I attempt to program (05),(01), (02), (03), (00), (00) to zones 1 thru 6 respectively. the alamr goes of and I cannot shut if off without disconecting power and battery.
Also, after the first attempt, when I enter *8 5555 to enter system as installer...that does not function either as I never get a "ready" light and after a delayu the alrm goes off again and I am back at square one.
Could I have accidentally changed the master 5555 code? Do i need resistors on zones 5 and 6?
Any help will be appreciated
Old 02-08-13, 09:30 PM
Received 92 Votes on 85 Posts
You don't need resistors if the eol requirement is turned off in programming.
Yes, it sounds like you accidentally changed the installer code. Do a hardware default and start over.
