Ademco Vista 15p Fault Codes 09 and 107
Old 02-16-13, 03:42 PM
Hi,
I have an Ademco Vista 15p system and it is displaying fault codes 09 and 107. I only have 6 zones, so I don't think I need a zone extender. I tried disabling zone 09, but I am not sure I am pressing the correct sequence. Unfortunately I don't have an alphanumeric keypad, just the basic led one.
Here's what I was trying to do to bypass zone 09:
installercode+800
*56
Press * until I get to 09 then * until I see a 10.
Then I enter 00 to try to disable and then * to confirm.
Then I press *999 to exit the programming mode.
After a minute the alarm starts continuously beeping so I enter the master code and OFF.
Then it still displays 09 and 107 fault codes.
Thanks for any help!
-Acki
Old 02-16-13, 06:51 PM
Received 38 Votes on 37 Posts
I'm afraid that you don't have the right keystroke sequence, at all.
Were I to guess, I'd say that you have zone 9 accidentally programmed into the system, which is making the system look for a hardwired zone expander (the trouble 107)
Without the correct alpha (6160) keypad, this is dicy at best, because you may have made changes trying to program zones blindly; but here goes...follow along with the *56 instructions.
To delete zone 9:
Go to program with [installer code] + 8 + 00
*56
0* (set to confirm, NO)
09* (select zone 9)
* (accept the summary screen and move to next prompt)
00* (to set the zone as unused)
press * 7-8 times to get back to the zone select prompt.
press 00 to get out of *56 programming.
You may have to simply wait until the programming times out if you can't find your way back to the exit prompt.
