Can I put (2) 30 Watt Ademco Sirens on my Vista 20P system?
Old 04-16-13, 05:00 PM
I have a Safewatch Pro 3000 by ADT originally but now monitored by a different company. I originally had a siren installed but it has since croaked. I am going to replace it but thought that it would be better to have one at the other end of the house also, if possible. Can I wire 2 of these in parallel or would that overload the Main Board? Thanks in advance, Bob
Old 04-16-13, 07:59 PM
Received 38 Votes on 37 Posts
Look at the current rating for the devices you want to use and add them up. As long as you stay under 2 amps, including the power used by your keypad(s), they should work (yes, in parallel...)
Old 04-17-13, 03:22 AM
Thank you
Thank you sir for your help!
