Confusing Codes
Old 05-05-13, 12:58 PM
Received 1 Vote on 1 Post
Question Confusing Codes
Is the System Master Code and Installer Code one in the same? Thanks.
Old 05-05-13, 01:08 PM
Received 379 Votes on 356 Posts
Depends on the system.
On some the system master code is above the installer code.
Old 05-05-13, 06:13 PM
So if I wanted to program a new keypad, how would I know what code(s) to input to start the process? Also, how would I identify the Installer and/or System Master Code? The keypad in question will be an Ademco/Vista/Honeywell 6140 or 6150 type device. Thank you once again.
Old 05-05-13, 08:15 PM
Received 32 Votes on 31 Posts
The base system model is the important thing. The different Vista models require different settings for the keypads. For _most_ Ademco/Honeywell Vista systems, the installer code is used to set the master user code.
