DSC PK5508 Problem - Stuck in house
Old 05-10-13, 04:07 PM
L
Hey there,
I have a weird one but we'll see if anyone knows how to help..
I'm currently renting an apartment with a DSC PK5508 Alarm installed, it's always been disarmed but I accidentally learned on the control panel and somehow armed the system.
Here's the tricky bit, I have NO idea what the access code to disarm it is nor does my landlord who actually owns the house, she says the system already installed when she bought the house.
What can I do to disarm the alarm or even just unplug it so it doesn't go off every time i open a door or window
Any help would be amazing!
- Katie
Old 05-10-13, 05:12 PM
Received 913 Votes on 853 Posts
Welcome to the forums.
The 5508 is just a keypad. There should be a control box somewhere as well as a big plug in power supply. Open the alarm panel and disconnect one of the battery leads. Unplug power supply from wall.
May be held in place with a center screw into the receptacle. Be careful removing that screws as wall plate could land on the prongs of the adapter.
Old 05-10-13, 06:06 PM
L
Wow thanks for you help!!
I found the control box but I dont know which one to unplug..
I took photos, maybe you could help?
imgur: the simple image sharer
Old 05-10-13, 07:08 PM
Received 77 Votes on 73 Posts
Unplug either of the wires on the battery, then loosen the set screw and take the wire out of either one of the terminals labeled "AC" (it's 16vac, so it's quite safe) and wrap it with tape. That will shut down the system, fully.
Old 05-10-13, 07:14 PM
T
Remove/cut one of the white wires on the far left and disconnect a lead/wire from the battery [large, black cube] and your done.
Old 05-10-13, 07:27 PM
L
So according to http://i.imgur.com/4SnXpKj.jpg
which labeled wires do I cut/remove
and how do i properly disconnect the battery? is the battery cable the red/black cable on the far left?
Old 05-10-13, 10:20 PM
Yes....the red/black wires go to the battery. If that plug wont unplug from the board...... disconnect either red or black wire from battery.
Using a small screwdriver.... remove and tape the first wire. If you don't have a small screwdriver just cut the wire and insulate it.
Old 02-23-14, 08:09 AM
U
pk5508
How do I remove a DSC PK 5508 from the wall?
Urgent
Old 02-23-14, 08:36 AM
Look around the edges of the housing. There are small slots that you can slip a small flat screwdriver into. Pry gently, and the keypad assembly will come out of the mounting base, and you will have access to the screws holding it to the wall.
