safewatch pro3000 codes
Old 06-09-13, 10:25 PM
K
I have a ADT safewatch pro3000
I reset the power and got a code of 00-05-10-01 with 3 chirps
how do I get the installer code to change my master code?
Old 06-10-13, 03:51 AM
Received 89 Votes on 83 Posts
Once you get into programming with * + #:
#20 will read back the installer code, one digit at a time (ignore leading zeros)
Exit programming with *99.
In normal run mode:
[installer code] + 8 + 02 + [new master code]
Do this in one smooth entry, hesitating more than a couple of seconds between keystrokes will kick out of code programming and the new code won't take.
Read more: http://www.doityourself.com/forum/el...#ixzz2VoFFJEg9
Old 08-26-13, 08:46 AM
W
Additional Question Regarding Safewatch Codes
Hey folks,
Since the original question on this thread was answered, I thought I would piggyback on this thread since the contributors seem really knowledgable....
I just swaped out a failing magnetic door sensor and I now get a chime when I close the door instead of opening. I also get a "not ready" at the panel even though the door is closed and making a good contact. It seems to me that the state the system is seeing is just reversed. Is there a code that needs to be entered to re-set the state of the affected zone? I called ADT and they won't answer the question but will be happy to send a technician to enter the code for around $125! Any assistance would be appreciated, as I would like to avoid the ADT gouging.
Regards,
Warren
Old 08-26-13, 10:09 AM
I have a strong suspicion that you purchased a Normally Closed contact that opens in the presence of the magnet instead of a Normally Open contact. There is no programming, you need the correct type of contact.
Old 08-26-13, 05:18 PM
T
Do you have a programming keypad? And is this a zone #1-8?
