DSC pc1616 STAY arming exit delay not adjustable? 90s no matter what?
Old 06-17-13, 08:03 PM
Hold STAY button until it goes into arming mode. PK5500 alpha pad says "exit delay" is in place.
I have [005] [01] data set at
030 030 030
Dly1 Dly2 ExitDelay
so, long after 30s per my stopwatch, the system is STILL in "exit delay" mode.
I get about 90s of Exit Delay... while entering STAY mode
I tried changing the 3rd data set in [005] [01] to 005 but no change was observed in the Exit Delay for a STAY arming term.
Old 06-17-13, 08:50 PM
Received 340 Votes on 318 Posts
I'm not quite following you.... it may be too late for me.
I know some alarm systems need to see one of the delayed doors opened during the cycle.
Old 06-18-13, 03:28 AM
Received 25 Votes on 24 Posts
It sounds like you are making the correct entries.
005
01
030 030 030 # should set all of the delays to 30sec.
Old 06-20-13, 06:23 AM
LOCKtec's Avatar
if you open & close a door while in the exit delay status, it will think you have exited & then any zones programmed as interior will be active.
try the *9 xxxx arming and see what it says -
xxxx = your code
in your case its letting you know that the system is armed- ( red lock on ) and that delay is set for entry.
doing the star 9 & code will show armed with NO entry delay
nothings wrong.... its working
