Which Keypad do I need to reprogram Ademco 30PSE system
Old 06-26-13, 06:46 AM
My system has been working for years, I started having issue with 2 window switches. I had to power off the system and back on to recover the installers code. Only to realize I can program the 2 new sensors I purchased with the SA6150AS-1 keypad on my system.
also in the middle of attempting, my system as stopped alerting on the wireless devices when a door or window is opened and says to check all zones now.
which keypad will work with my system for reprogramming?
I have a ademco 30pse and the adaptors are 5800 series.
thanks
Don
Old 06-26-13, 08:16 AM
Received 25 Votes on 24 Posts
6139 or 6160. You need a 2-line alpha keypad to access the zone programming menus. I suspect that you may have removed your existing RF receiver keypad, which is why your transmitters stopped working.
Old 06-26-13, 12:19 PM
I only have a Wired keypad on the system(SA6150AS-1), I attempted to perform the *56 combination, but since its not a alpha keypad, it just did nothing and flashed a 56 00 code. not that, that would help?
so I can replace the current 6150 with a 6160 and I should be good to go?
Don
Old 06-26-13, 02:35 PM
Or in addition to the 6150. They will co-exist just fine.
Old 06-26-13, 04:35 PM
MrRonFL ,
Thank you! I will order that and get it (Hopefully) reprogrammed.
and to make sure its a Ademco VIA 30pse (i just got home to confirm it)
Don
