Ranger American PC1555RKZ System Light On - Can't troubleshoot
Old 06-30-13, 11:50 AM
nugmebot's Avatar
So this morning my sister accidentally opened a door while the alarm was armed. She put in the code after a second and it turned off. Now the yellow system light is on. I've looked across this forum and others and looked up the manual to see what the trouble is, however when I do the *2 code, none of the zone area lights turn on to tell me what the cause is. When I press *2, the system light just flashes. Any help?
Old 06-30-13, 12:46 PM
Received 27 Votes on 26 Posts
First, make sure you are out of alarm memory mode by pressing #.
Try arming and disarming the system. Sometimes, that's all that you need.
Otherwise, lacking a trouble indication, all I can suggest is to power the system down (ac power and battery, then reconnect the battery and ac power after a minute or so) Reset the clock, and that will clear the mystery trouble (usually). You shouldn't need to do this, but sometimes electronic devices do glitch.
