Ademco vista 10se 09 not ready installer code ? Can't get in please Help!
Old 07-26-13, 04:00 AM
Ademco vista 10se 09 not ready installer code ? Can't get in please Help! joe
Old 07-26-13, 09:33 AM
Received 28 Votes on 27 Posts
Installer manual: http://www.ameritechsystems.net/publ...stallation.pdf
The Check 9 is because there is a problem with a wireless receiver or hardwire zone expander.
Power the system down, both AC and battery then restore AC power.
If you press * + # within 50 sec of restoring AC power, it should jump into programing.
Enter #20 and it will read back the installer code, one digit at a time (ignore leading zeros). Write it down.
Enter *41*, *42* & *94* to erase all of the dialer phone numbers and disable the dialer.
Enter *99 to exit programming (90% of the time it will be disarmed)
Next enter [installer code] + 8 + 2 + [new master code] (Do this in a smooth entry. If you hesitate more than a couple of seconds between keystrokes, the new code won't take)
Test the new master code by turning on/off the chime feature.
