ADT Safewatch Pro 3000 CO Sensor Replacement
Old 08-16-13, 01:36 PM
Cool ADT Safewatch Pro 3000 CO Sensor Replacement
Hi,
Any recommendations for a replacement Carbon Monoxide sensor?
My current sensor is probably 20 years old. I do not have any idea who the manufacturer is or was. There is no end of life light or similar attribute for this sensor. Would like to stay wired.
System: ADT Safewatch Pro 3000
Wired CO sensor (2 conductor)
12v system
Thanks.
Old 08-16-13, 03:25 PM
Received 32 Votes on 31 Posts
Hmmmm---a 2-Wire CO detector that's 20+ years old...
Low voltage CO detectors are generally going to be a 4-wire device...
Are you sure that it's not a 4-wire device that is just being supplied with 12v power by your security system? Often the brand/model label is on the bottom of the device and you would have to dismount it to view it...
Old 08-19-13, 01:19 PM
Cool
That's all I see is 2 wires coming from the wall.
There is no brand name on any part of the device, including the small circuit board inside.
Not sure what it is then...
Old 08-19-13, 07:56 PM
Do you see 2 _wires_ or two _cables_? If you have 2 2-conductor cables, then you may have a 4-wire device.
Old 08-19-13, 08:07 PM
Received 33 Votes on 25 Posts
I agree, a two-wire carbon monoxide detector would be unusual. Please post some pictures of this unit.
