dsc powerseries pc1555mx
can anybody help me please, I have this alarm and never used it. it was installed and as far as I can see never switched on, do I need to call someone to switch it on? thanks
Installer manual: http://www.mainelectronics.com/pdf/PC1555Install.pdf
If this system has never been powered up, then it's probably still at factory defaults, and you may be able to use it.
That said: Often installers do prewired installs like this and leave the control in a disabled condition, so it's possible that you may not be able to do much with this.
Are all the zones and keypads connected to the control panel? Is there a transformer connected just not plugged in? If you have even a little tech skill it is possible to finish setting it up. There really are only a few things you need to program when first setting it up.
