Smoke detector won't stop chirping
Hoping this is the correct place to ask this?
I replaced the battery in our upstairs smoke detector about 2 months ago because it started chirping. It was fine for about a month, then started doing the low battery chirp again. The 9-volt I had put in it had been sitting for awhile, so I thought maybe it was bad, and I bought a brand new battery to put in there.
Problem is the damn thing is STILL chirping. In fact it chirps even when you remove the battery, With the battery in it tests fine, but chirps every minute. I tried a fix I saw online of removing the battery and holding down the test button, but no go. Do I just need to replace the smoke detector?
