ADT Focus 200P
Old 01-18-14, 05:18 PM
ADT Focus 200P
I was left with system from previous owner.I need to access programming to change monitoring information for a new monitoring account.
Old 01-18-14, 09:36 PM
Received 521 Votes on 491 Posts
Welcome to the forums.
I'm pretty sure that Focus system is a Radionics/Bosch panel. That would mean you could only change limited functions from the keypad and phone/account information is not among the choices.
That alarm may still be property of ADT which means you'd have to go to them for monitoring as well as changes.
download_manual_focus_200.pdf
We'll see if someone else has further info for you.
Old 01-19-14, 06:33 PM
Received 38 Votes on 37 Posts
Nope, that's it in a nutshell. The Focus panels are custom modified for ADT, and they can't really be modified without the ADT installer's assistance. Scrape it off the wall, and start over with a standard, non-proprietary model system.
Old 07-21-14, 01:33 PM
The ADT techs in my area use the following as the pass code to get into programming. Not sure if it will work for you but give it a try.
991237 or 991236
Hope this helps.
