concord 4 fire trouble
I recently replaced my alarm panel with a concord 4 system due to a lighting
strike. We replaced all the sensors, smokes and thermals. The alarm side works great but when we hook the fire side to zone 8 I get a fire trouble signal. Checked all the connections, checked continuity on the line ohmed out EOL and still get the same code. Any suggestions?? I am at a loss at this point.
Jon
Jon
Double check your wiring configuration and programming against the diagram and instructions in the Concord 4 manuals. Concords use a fire zone setup that's unique to this family of panels, and is fairly easy to get wrong, if you are new to alarm wiring.
