Mooose z1100 keypad replacement
Old 01-31-14, 06:43 AM
I have a Moose z1100 system with two keypads (the original keypads are nutech)and one of the keypads went bad so I purchased two Z1100r keypads on ebay to replace my old ones. My question is what do I have to do to replace them? Just turn the power switch off? Also the new keypads have 4 wires coming out of the wire harness, do I just tiwst them together with the 4 wires coming out of the wall from the system? Thanks in advance.
Old 01-31-14, 11:21 AM
Received 30 Votes on 29 Posts
Turn the power switch off. Use crimp connectors to swap the wires. "Twist and tape" will fail on you, sooner or later. That should be all you need to do.
