ADT System with DSC SCW9047 Missing Motion Sensor
Old 02-11-14, 07:34 PM
I recently moved into a home with an ADT system with a DSC SCW9047. One of my zones (basement) is a motion sensor, but the motion sensor is nowhere to be found in the house. Who knows what happened to it from the previous owners...Without it, I can only arm by bypassing the zone. I am aware how to do this, but it is a lengthy process when in a rush out the house. Can I remove/delete this zone? Can I buy a replacement motion sensor? If I am able to buy a replacement, how easy is it to program into the system? Any other suggestions???
I do have the master code if needed.
Thank You.
Old 02-12-14, 06:16 AM
Received 77 Votes on 73 Posts
Do you have the master code or the _installer_ code?
The latter is what it takes to get into programming to remove or replace the missing transmitter.
Old 02-12-14, 07:36 AM
Thank you for your assistance, I am not aware of the Installer Code. Is their a means of trying to identify this?
Old 02-12-14, 08:03 AM
I did find the Installer Code after doing a little research. Am I now able to add/delete zones and add/delete sensors?
Old 02-12-14, 02:25 PM
Yup.
Installer manual: http://www.alarmhow.net/manuals/DSC/...n%20Manual.pdf
You go to program with *8 [installer code]
804
Enter the zone number, then either key in the new device serial number, or delete the old one.
You may have to go to zone programming and reset that zone number as a null zone.
