Need help with OLD ADT Safewatch Pro 3000EN
Old 02-12-14, 09:01 AM
V
This morning I had a window sensor show a fault. It was working last night. The label in the wiring box says safewatch pro 3000en, and my keypad only shows numeric faults, such as "03". The system is over 10yrs old (probably 17) based on the age of the house and how long we have owned it. Do I have the 951wg-wh ademco 3/8" wired sensor? If I can figure out which sensor went bad, is it a simple replacement, or do I have a mess of reprogramming to do?
thanks!
Old 02-12-14, 09:05 AM
V
I have checked to make sure all the window magnets have not shifted. I have thunked all the sensors with a screwdriver in case the switch was stuck. No changes. Still showing an open fault.
Old 02-12-14, 02:29 PM
Received 77 Votes on 73 Posts
Hardwired contacts are just dumb magnetic switches. Get one the same size and color and swap it out. Brand does not matter, they are commodity items. Double check that the problem is not the field wiring by twisting the wires together before you connect the new one to verify that the zone closes.
