Ademco Vista 20 (4150) showing low battery after battery swapped out
Old 03-11-14, 07:36 AM
G
Our Ademco Vista 20 (Model 4150) Control Panel is showing "lo battery" on all of our keypads. We have swapped out the battery and it's still showing. I checked the voltage on the battery (12.8 volts). I checked the battery lead wires coming from the panel with the battery detached to see if the charging circuit is working. I read 12.8 volts that fluctuates as I leave the leads on for a few seconds. What can I check next or what can I do to clear the problem?
Old 03-11-14, 07:40 PM
Received 924 Votes on 863 Posts
Welcome to the forums.
Check your 16.5vac transformer input on the alarm board. It should be at least 16.5vac.
Did you install a new battery ?
I don't think there's a fuse for the battery itself.
If the transformer is good and that's a new battery..... then you have a charge problem on the alarm board. I don't think it's a serviceable problem.
Old 03-15-14, 09:15 PM
Received 77 Votes on 73 Posts
Many of the older systems only check the battery once a day. Leave the battery alone for 24 hours (some batteries come partially charged...)
