concord 4 everything works but no audible alarm exept keypad speaker
Old 03-12-14, 01:19 PM
Every thing works but alarm speakers ,but work on keypad speaked .I have a speaker indoor and outside the adt service person might have turned it off audible alarm when working on system .It even sends me text and email when its active.
Old 03-12-14, 05:47 PM
T
Check the wiring inside the panel.
If a tech was working on it, he might have temporarily disconnected them and forgot to reconnect when finished.
Old 03-12-14, 06:39 PM
No they are both wired to the speaker out2
Old 03-13-14, 06:18 AM
I also dont have adt services
I lost my job so I dont have adt right now dont know if this has somthing to do with it. Any help I would appreciate it .
Old 03-13-14, 04:57 PM
G
Output 2 programming may have been changed...
Old 03-13-14, 05:20 PM
how can I fix it or turn it or is there a code
I think he may have turned it off when he put in a wired window and there must be a code to turn it on hasnt went off in awhile so didnt no it wasnt on .Thank you for the help.
Old 03-14-14, 06:21 PM
could I move it to the speaker 1 hookup
And is there a code to make it work in that spot .I would really appreciate any help thank you.
Old 03-18-14, 06:38 AM
Does anyone know where I could get this info
I would appreciate any help thank you.
Old 03-18-14, 10:21 AM
Received 77 Votes on 73 Posts
First, the assumption that the programming has been altered may be incorrect. There would be no reason for a technician to disable the output programming in the process of installing a wired contact.
If it worked before, the greater likelihood is that your speaker may have simply failed. Simple test, connect the speaker output leads to an audio source, or a tone generator. Does it make noise? If yes, _then_ it's time to chase programming issues. If no, replace the speaker and/or check wiring.
