ITI caretaker plus security system
Old 03-20-14, 02:23 PM
I just bought a new home and it has a ITI caretaker plus security system installed...the older lady that I bought the home from forgot the 4 digit code....how can I reset the code without knowing the current code?
Old 03-21-14, 03:34 AM
Received 77 Votes on 73 Posts
Installer manual: http://interlogix.com/_/assets/libra...anual_1994.pdf
User manual: http://www.proscansecurity.com/ITI%2...r%20Manual.pdf
Unfortunately, like it's modern descendants like Concord and Simon, if you don't know the current user code, all you can do is a full memory clear, which requires programming everything from scratch.
I would recommend, strongly that you consider replacing the control and keypads with a modern Concord panel (which will be compatible with 99% of the existing transmitters). This is, after all, a nearly 20 year old piece of hardware.
