KeyPad A1110ST
KeyPad A1110ST
Hi
Is Keypad A1110ST compatible with Moose Z1100ST or Z2100st keypad? I mean I can replace Z2100st or z1100st by A1110ST?
Thanks
Thanks
Thank you for your reply . There is sticker on board of the keypad says " "SAFEWATCH CUSTOM 1A1110ST-50AB 38/00Z". I do not know if this info may help?
Thanks again
Thanks again
That means that it's the ADT modified version. The keypad itself will probably work with an unmodified Z1100e, but I don't think those keypads are backward compatible with the two earlier Z1100 system models.
