ademco vista 20p low bat rpt
Old 06-04-14, 10:56 PM
hi all, i have vista 20p low bat display on keypad & i changed new battery,i adjust time/date after 3days low battery rpt not clear on keypad i thing battery defect, i changed another one , week later low battery rpt on keypad still there any help is greatly appreciate
Old 06-04-14, 11:40 PM
Received 508 Votes on 478 Posts
Welcome to the forums.
Try entering your code + off. Or try arming and disarming the system.
Old 06-05-14, 03:37 AM
Received 38 Votes on 37 Posts
Also, if the low bat is accompanied by a zone number, and you have wireless transmitters, then it's a transmitter battery.
You do have to do as suggested with the code entry. Vista panels don't automatically clear troubles from the display.
Old 06-05-14, 01:37 PM
adamco vista 20p low bat rpt
thanks you for your input ,i did all but low bat rpt on keypad still there, i think problem with wire motion detector because when i walk thru motion keypad beep 2 time,can i reprogram this zone thanks in advance
Old 06-05-14, 02:59 PM
In order to make alterations on the zone types, you need a 6160 (2-line Alpha) keypad to access the programming menus.
Old 06-05-14, 03:54 PM
ya my system have that thx
Old 06-06-14, 03:31 AM
Programming manual: http://site.aesecurity.com/Manuals/v...mmingguide.pdf
You use the *56 programming to change the zone type to an interior zone that doesn't chime.
