Vista 20P Fault 07
Old 06-13-14, 11:19 AM
Vista 20P Fault 07
Hi, I got this panel and a couple keypads from someone and I was trying to see if I could use it. I installed 2k resistors on all the zone connections. I got in with the default installer code and reset it to factory defaults. However when I power it up I get "disarmed hit * for faults". I press * and I get "Fault 07". I've found most of the literature on line but can't find anything explaining Fault 07. I'm not having any trouble accessing the installer mode and I can view/change codes without problems. Just don't know how to fix fault 07 because I don't know what it it?
Please help
Old 06-13-14, 04:43 PM
Received 46 Votes on 45 Posts
If you have Just 2k resistors from each zone input to common, and zone 7 is still showing open, then that means that the board you have has a damaged zone 7 input (unless you accidentally changed that zone in programming from EOL to NC).
