Ademco alarm problem. model infra 6/16
Closed Thread
Old 07-21-14, 11:08 AM
Re Alarm :Ademco infra 6/16
We had a power cut last night which set off our alarm, this has happened before and we simply put in our code and then press off
This did not work ( it was late and half awake we think we possibly got code wrong)
We only have the installation instructions and done all sorts of things to stop it, including taking off the cover and disarming the power and indeed battery and fuse.
Today we tried to reset it but to no avail, even though we done a reset of engineer code and all sorts of other things we read in said instructions.
Google even couldn’t help!
We now have it showing code 5F not ready and if we attempt to do anything with it it goes off.
It is indeed an old system but we have had all the indoor sensors replaced a couple of years back and an engineer ( now deceased)serviced it for us when he installed these
Please can you advise
Thank you very much indeed.
Old 07-21-14, 06:54 PM
Received 38 Votes on 37 Posts
Hmmm, this thing is old enough, and an overseas model, to boot, that even the Honeywell website doesn't have anything useful. You may have to grit your teeth, and try one of the online manual archives. If you are determined to squeeze a few more years out of the system, the nominal cost of the download might be worth your while.
Sadly, these older non-north American models are so different from current models, that it's hard to even hazard a guess without reference material.
Old 07-22-14, 03:04 AM
Thank you MrRonFL for your reply. I have found several manuals online for similar models but they all just say to put in code and then press off ! Which of course does not work I think we may have to get a whole new system
Old 07-22-14, 03:30 AM
What you want is the installer/engineer manual. Those usually have more by way of troubleshooting. From what I understand, though, this one had pretty minimal documentation, even when it was new.
Old 07-22-14, 12:01 PM
It is the installation instruction manual we have and I followed the instructions on how to reset the engineers code, which worked, but... we still ended up with code 5F when we turn it on the alarm goes off. I cannot seem to find anyone in the UK that can help/reset/fix this, which is very disappointing
Closed Thread
