How to install Signal Repeater Booster Extender
Old 07-29-14, 08:43 AM
Hi I have a generic chinese wireless alarm system. Because some sensors are far away from the central unit, I bought a Signal Repeater to extend the wireless zone, but I can't figure out how it works. Does anyone have one of these and knows how it functions?
433MHz Signal Repeater Booster Extender to Wireless Range 300 1000M for Alarm | eBay
It came with a paper that says:
"Signal Repeater (433 MHZ) guideline
About the 4 dipswitch of the signal repeater, they are for setting the resistence of alarm accessories which need to amplify the signal."
I see the switches, but have no idea which one I should set. sometimes if I fumble with them the led is green, other times is flashing red, but the sensors that are more far awauy from the central unit continue to not function.
Can anybody help me?
Thanks
Old 07-29-14, 09:34 AM
Received 315 Votes on 289 Posts
On your existing alarm system do the sensors have dip switches inside them? If so have you tried setting the repeater the same?
Old 07-29-14, 09:45 AM
No, the sensor only have a ON/OFF switch.
Old 07-29-14, 06:40 PM
Received 38 Votes on 37 Posts
Typically, range extenders are made to conform to the default coding of a particular receiver system. There's really no such thing as a generic range extender for security wireless. If your range extender isn't from the same brand family as your transmitters and receiver, then it's not going to work.
