4110xm hit by lightning
Old 07-29-14, 07:49 PM
Lightning hit my 4110xm while unarmed. Siren went off and I had to disconnect from 110 to quiet siren . I think the board is toast. When I plug the system in the siren goes off but keypad does not light up or respond.
If I replace the board, will I have to do any programming? I don't have any install instructions but I am sure that I can wire the board correctly. Thanks for any help you can give me...Larry
Old 07-30-14, 03:33 AM
Received 36 Votes on 35 Posts
You will be starting from scratch. The 4110xm is a long-discontinued model. The equivalent system in current production is the Vista 10p or Vista 15p or Vista 20p.
The newer boards will fit the same mounts in your existing enclosure, but you will also need a 6160 keypad to program the new board.
Old 07-30-14, 12:40 PM
If I find another 4110xm board, will it plug and play or will I have to reprogram the system? Thanks....Larry
Old 07-30-14, 05:46 PM
Yes, you will have to reprogram the system to match your configuration.
