unable to clear FC off my safewatch 3000 ADT system
Old 08-13-14, 06:47 PM
Am unable to clear FC off my safewatch 3000 ADT system. Don't have manual or installer codes - did we search and tried all installer codes listed; none worked and I'm not sure how to get FC cleared and system fully OFF as I have no need for it. Tried calling ADT & got the same answers as everyone else on these similar threads. Help please - thanks!!
Old 08-13-14, 07:45 PM
Received 23 Votes on 22 Posts
A SW 3000 is a modified Vista 20p. Programming & Installer manual: http://www.devconsecurity.com/pdf/Vista20p.pdf
http://www.statcommunications.com/do...%20Rev%20A.pdf
Power the system down (both battery and AC)
Within 50 seconds after restoring AC power at any keypad, press * + # at the same time.
It should come up in programming mode.
Press #20 and the installer code will read back, one digit at a time (ignore leading zeros)
press *99 to exit programming
Enter [installer code] + 8 + 02 + [new master code] (do this in one smooth sequence; if you hesitate more than a couple of seconds between keystrokes the code won't take)
Test the master code by turning the chime on and off.
Test the n
