Electronic Home Alarm system issue
Old 08-27-14, 11:33 AM
Post Electronic Home Alarm system issue
Hello,
We bought a house with a DSC Power632 /PC1555 alarm system.
It's was not connected to a central (local use only).
We did not use it and did not armed it ...
A few months ago it's was showing 'trouble' AND we did not do anything ...
Now, it's dead (no light on the keypad).
So, I have replace the battery with a new one (PK12V7.2 12 V 7.2Ah) AND replace the AC adapter with a new one.
Nothing is happenning (still dead) ANY IDEA ??
Thanks in advance
Marcel
Old 08-27-14, 03:01 PM
Received 35 Votes on 34 Posts
First, verify that you are actually getting 16VAC from the transformer to the first two terminals on the motherboard. If so, and the system still doesn't start there remains 3 possibilities:
You could have a wire crushed, somewhere that's shorting out the DC power.
You could have a motion detector, glass break, or other power using device that's failed in a short.
Or the motherboard has fully failed.
To check the first two. Disconnect everything from Aux power other than the keypads.
