No Master installer code
Old 09-08-14, 08:18 AM
System: DSC power832 PC5010 CP-01
System worked before but is dead now. Determined transformer OK but battery is dead and will be replaced. Plan to operate as Local mode with no monitoring but want siren and chimes to work when ARMED.
Steps to bring back up
- Plug in transformer and reconnect new battery then
- Try master codes *8 xxxx If unsuccessful
- Try to reset to factory defaults and reprogram
- If unsuccessful (or LOCKED), replace control board, move wires over, and reprogram.
Q1 If control board is bad, where to get best buy on PC 1832 Control board. Is this the right replacement board?
Q2 Any comments on this plan. New to security systems.
Old 09-12-14, 05:52 AM
Control Board Answer?? Is PC 1832 the right replacement board for DSC power832 PC5010 CP-01? Plan to replace battery 7AH tomorrow.
Last edited by hfuller; 09-12-14 at 06:01 AM. Reason: transformer replaced with battery
Old 09-12-14, 06:12 PM
Received 38 Votes on 37 Posts
Yes, the PC1832 is the current model equivalent.
Old 09-14-14, 01:17 PM
Keypads Locked. Original installer went out of business. Plan to replace control board with PC1832.
Q2 How do you add a siren to the set up.
Old 09-14-14, 05:11 PM
There should have been one in the original setup. Are there wires on the siren/bell terminals; or are you trying to add an additional one?
Simple test to see if you already have one (sometimes they are in the attic): connect a 12v battery to the siren wires. If you have one in working condition, you will be able to find it...
In either case, any 12v alarm siren, within the amp draw limit of your alarm control, will work just fine. There's no special configuration.
Old 09-14-14, 06:07 PM
Owner says no siren was installed but there are a least 2 or more wires on the bell terminals. Will try putting 12 v from battery as you suggest.
