DSC Power832 PC5010 v2.0
Old 09-20-14, 08:43 AM
Hi
I received a old alarm system from a family member that was used in a house they bought. I have the master code but not the installer code. I installed it in my farmstall ,but now it shows errors on 3 and 4 if I press *2. There are no cellphone reception or telephone only a IP dataphone. Can I disable the telephone line option without installer code or what other options do I have?
Old 09-20-14, 08:03 PM
Received 38 Votes on 37 Posts
Without an installer code, you need to default the system (which you really needed to do before re-using the alarm control in a new location).
The basic hardware default for a _Power Series_ panel is as follows:
(Check the installer manual _first_; there can be small variations on this with some of the variant models)
1. Remove AC and battery from the panel.
2. Remove all wires from the Zone 1 and PGM1 terminals.
3. With a piece of wire short the Zone 1 terminal to the PGM1
terminal.
4. Apply AC power to the main panel.
5. When Zone Light 1 is lit on the keypad the default is complete.
6. Remove AC power from the control
7. Reconnect all original wiring and power up the control.
Read more: http://www.doityourself.com/forum/el...#ixzz3DuaJmf5s
Once you default you will have to configure everything from scratch, but the installer code will default back to 5010 or 5555.
