6160 keypads don't beep for countdown when entering/leaving
Old 09-20-14, 09:18 PM
Have an odd issue here. Had a new Vista 20p system installed recently with 3 6160 keypads. Only one of them does the countdown beeps when arming/disarming the system and when the system is in an alarm. All 3 of the keypads chime when doors are opened and closed and beep when keys are pressed. Is there a way to enable the countdown beeps and alarm sounds on the other two keypads?
Old 09-21-14, 08:13 AM
Received 38 Votes on 37 Posts
For whatever reason, when they activated your two additional keypads, they turned off the entry/exit and arm/disarm sounds. It's easy to turn on.
[installer code] + 8 + 00
*190 1 0
*191 1 0
*99 to exit programming.
Programming manual: http://www.nacdivisions.com/document...5p-program.pdf
