Trouble programming 5820l to Vista 20p via 5881ENM
Old 11-03-14, 10:56 AM
Unhappy Trouble programming 5820l to Vista 20p via 5881ENM
hi
My first thread here, the forum has lots of info.
It's ADT Installed SafeWatch Pro2000 equipment, to which I have wired up the Honeywell 5881ENM and am trying to add 2 5820L sensors on 2 of my entry/exit doors.
I did swap out my basic keypad with the 6160 (hardwired) keypad.
Am having challenges trying to get the sensors added:
I do have the installer code and am able to get into the programming for Zone 9 via *56.
however, once I pass the report for Zone 9 and start making changes, the navigation does NOT take me into the section wherein I can specify the "Partition", let the panel know that it is an "RF" type sensor etc. It completely bypasses that after I specify the "Zone type" and goes to labeling it and then exits out.
Similarly on the 6160, if I change the address to "16", it stops working with the panel until I make it non-addressable i.e. set it to "31". Did do the usual power-off, reboot, set it, power cycle it again, but it would just stop display anything at all until I set it back to 31.
The 5881ENM does blink when I open/close the door with the wireless 5820L sensor. The DIP switches on the 5881 have been left untouched.
Not sure if this is an issue with the panel at all?
Looking forward to some assistance here, spent all day yesterday breaking head on it to no avail.
thanks
BigMots
Old 11-03-14, 11:21 AM
Be sure you are pressing * after your entry and not #...?
Old 11-03-14, 11:26 AM
Actually on that panel, I think you will need to start your wireless zones on zone 10
Old 11-03-14, 02:34 PM
hmm ok, why is that. That said, will give it a try and report back.
thanks
BigMots
Old 11-03-14, 02:44 PM
Received 34 Votes on 33 Posts
On a Vista 20se/Safewatch 2000, zone 9 is used for a particular system trouble, so all expansion zones begin with zone 10.
Old 11-03-14, 05:50 PM
Ah I see, did not know that, appreciate you both giving me that info. Will try with Zone 10 and report back on this thread.
thanks
BigMots
Old 11-03-14, 06:00 PM
Unfortunately Zone 10 is a no-go for me. It will not let me type that zone at all period. I do have the 5881 enm hooked up and the 5820l hooked up as well. So back to the drawing board
BigMots
Old 11-04-14, 03:59 AM
What manual are you using for reference?
If you have a Safewatch Pro 2000 it's not the same manual as a V20p.
http://www.reedsecurity.com/pdf/Vista20SEUserManual.pdf
Old 11-04-14, 11:30 AM
thank you for the link to the manual.
This may sound strange but, when I do enter the programming mode via *56 the responses I get back are more in line with a Vista 20P rather than a Vista 20SE (based on what I see in the manual).
thanks
BigMots
Old 11-04-14, 12:41 PM
All I can suggest is to check your model number. Sometimes newer control boards get installed into older enclosures. Look on the outer edges of the main PC board. There should be a part number beginning with "SAV".
