PC1832 Stay and Then Leave The House
Old 11-28-14, 07:31 AM
O
Hi
I recently installed a PC1832 which includes 1 motion detector. My gf and I work different shifts and when I leave the house in the morning I arm the system with STAY function because otherwise she would set off the motion detector. But the motion detector has been triggering the alarm anyways.
I realized that even though arming with STAY does activate the Bypass function, once I open the door, the bypass function disappears.
Is there a way to correct this so the bypass function works even if I open the door to leave? Motion detector is currently defined as a 05 zone.
Thanks.
Old 11-28-14, 10:28 AM
How do you arm? Type the code or hold the button?
If you use the code then it will arm away with motion IF you open the door.
